Fuel problems?
ssjkouru
72
Jun 27, 2010
Minneapolis, Minnesota
Hey guys ssjkouru here, long time lurker 2nd time poster. I've been searching the forums for a long time now but haven't found exactly anything to fit my problem. today I looked at my car and have a good assumption to what the problem is(and its a big one)
That being said I seem to be getting a a*#load amount of fuel into my system so much to the point that I get 11mpg. I have pops from the exhaust while driving which I believe is because of all the fuel getting down to my exhaust. I have most stock everything at the moment as far as I know. I often have to keep my foot on the gas while braking to keep the car from dying. in order to speed up the process i've tooken shots of my fuel system so you guys have a better look into what the problem may be. Any help to this problem is much appreciated
my assumption:there is no fuel pressure regulator =_=
Ive had the same problem of running extremely rich its annoying.Your car is dying because there is to much fuel going into the cylinders and it cant ignite it all,is your check engine light on if so check it see what code it gives you.Also no fpr is ###### the problem right there LOL.And if you have a friend with the same car swap his maf with yours and see what happens hope this helps and oh yea check your injectors too one could be stuck open dumping to much fuel in one cylinder thats what was wrong with mine either way easy fixes to your problem so don't worry
yeah my check engine light is on. how do I check to see what code it gives me? don't I use a voltmeter or something? so I was right I don't have a fpr. Blah :p thats a easy and simple bolt in tho.
