fuel problem help please!
primodts
Aug 3, 2004
Bath, New York
ok, heres' the problem, i go to start up and the car runs like crap, black smoke is pouring out of the exhaust, it won't idle, and i can't rev it up with out it drowning out the engine, i have negative boost pressure (vaccum) and after everytime i start it up i take the plugs out and theyr'e soaked and fouled out. i have 550 cc injectors, safc, big 16g, greddy fmic, i can't figure out the problem , i checked the fpr, i'm trying to get the car running as soon as i can, i can't figure out what is wrong, any suggestions?
oh yeah and another thing to add, gas pours out of the 4th cylinder at the exhaust manifold, and is running down into the crank and mixing with the oil, i just imagine this is because way too much unburned gas is running thru the cylinder, but thats' just another thing
What is your AFC set at? Did you remove some fuel in order to compensate for the larger injectors? What is your base fuel pressure set at (vacuum line off?)
