1G fuel pressure solenoid problem
x3jj3x
Feb 28, 2004
oglesby, Illinois
i was checkng all the connection on my 90 gsx cuz i changed everything and checked everything and it still wont run. so now i am checking all the connection in it and found out the fuel pressure solenoid is all screwed up somebody broke it and put some kind of rubber suff to reseal it and i think it is leaking vaccum if someone has any idea if this is the reason my car is not starting please say so thanx, and what could be done to fix it. and please give me the downlow about it thank you.
Read about the fuel pressure solenoid here.
http://members.shaw.ca/dsm.1000q/Engineprimer/solenoids.htm
Mine failed on my 2G a while back, and I drove around for months with the check engine light on. I had no problem starting the car, didn't blow anything up, etc. Of course, mine did not have some jerry-rigged fix like the one you have, so I can't say for sure whether that is the problem or not.
Ya you dont need the that. Just unhook the vav line and run the line from the FPR to the intake.
I've been running without mine like a year and a half now, works fine.
Hell I unbolted the whole bracket that holds them on and threw it out.
