Fuel Pressure Reading
Drifter27_04
335
Feb 13, 2005
Winston Salem, North Carolina
OK short and simple my fuel pressure starts to drop slowly after turning off the car. A friends fuel pressure can hold pressure through out the night.
Which of the two are correct to do and why/what would cause which ever one is wrong?
Thanks you all.
According to Aeromotive (your profile shows you have one), it is normal for their units to allow the pressure to bleed off. Mine was doing the same thing so I contacted Aeromotive and that is what they told me. They said something in the design that was incorporated to make them more accurate allowed this to happen.
Some members have posted saying their Aeromotive units do not bleed off. I couldn't tell you why that is.
Does your friend also have an Aeromotive AFPR?
Oh ok I was just thinking that I may have a injector leaking or something or somewhere in the system.
No he bought a Fuel Lab FPR.
Why not just use DSMLink to have the fuel pump turn on with the key in the "on" position? Leave it there for about 2 seconds, let the fuel pressure build, then start.
You don't need a laptop, as long as you set it and don't lose power to the ECU it will maintain your settings. We have a gauge on the FPR, so if I ever feel the need to check the pressure I just twist the key, walk to the front and check the pressure. The only downside is that it will run down your battery very fast if you forget about it and leave the key in the ignition in the second position. Ask me and my dead optima how we know.
