Fuel Pressure ? on an EVO III
Mitsu725
211
Mar 22, 2004
DAVIE, Florida
On the evo III turbo with an aeromotive fuel pressure regulator what should the pressure be, im gonna turn the boost all the way down with the turbo Xs but i was told the lowest it will go is 20lbs, so what should my fuel pressure be???
*EDIT*
Here ya go. Read this thread. Lots of good input.
Stock base fuel pressure:
1G - 36-37psi
2G - 42-43psi
Should be done at atmospheric pressure (without hose). You will want to put and pull the hose a few times just to be sure the pressure is set correctly.
