Fuel Line Damaged at Filter
swarm
DSMtuners Server Guru
466
Mar 26, 2004
Spokane, Washington
Hi.
I was replacing my fuel filter today when i twisted the metal line that comes off the bottom of the filter. :barf: I cut the line smoothly and attempted to re-add the flare.. but it came out again.. Should I just try to just re-flare it again, or do i have a better option? Can I use a rubber hose to extend it like 6 inches, then use another metal tube, flare it, and attach it that way?
Need some help here... Thanks
Second Question... How would I replace that fuel line completely? would I have to drop the suspension? :cry: :talon: :cry: :( :(
I destroyed my clutch fluid line awhile back. I fixed it once by double flaring it. It leaked. Tried again very carefully, and it has worked well for the past 9 months,
You can get a double flaring tool from any auto parts store. I got autozone's loaner tool for free when I did minel. Just follow the directions that come with it very carefully and you should be fine.
