fuel leaking around exhaust gaskets?
tazndrew04
471
5
Sep 3, 2009
Omaha, Nebraska
So ive noticed lately that fuel has been leaking where the exhaust gaskets are. Not around the turbo just where the downpipe and exhaust meet. I have 1050cc injectors and an afpr set to 43 psi and a walboro 255. Kinda stumped as to why theres fuel leaking around the gaskets. Is it because the fpr is set to 43psi or what might cause this?
Giving the info you did it sounds like your ECU is keeping your injectors on all the time instead of pulsing them on and off, I'd try swapping a new ECU in.
If your getting fuel into your exhaust then your cylinders are full of gasoline too, if you do it too much its possible to seize the motor because it will wash the cylinder walls. Once you get it resolved you'll want to do an oil change as well since theres gas mixed in the oil...
:dsm:
now heres the funny part,im running ecmlink with no gas on the dipstick when i take it out and smell it. So its could still be the ecu huh? When i pull the ecu out what pinout should i look at? The injector pinouts or what should i look at?
