fuel injector size
I need help! I just got a 95 gsx it runs but blows smoke when the turbo kicks.its my 5th dsm but first 4g63. it has 20g turbo,apexi safc 2 (that I know nothing about )and hks 272 cams. it had rc injectors but I have no clue how big they are? any advice in how to tell,also tuning?
1 this thread is 9 yesrs old!!! and its asking about injectors, 2 stsrt your own thread related to your problems, as a whole rsther jumping into this injector thread,
well I'm on probation still had to jump in to a conversation that I deliberately related towards the topic of injectors. thanks though for the administration attitude,if you read my post I was asking about my injectors size and how to locate and if that would affect my car and the smoke it blows
Your welcome on that, always here to make sure everyone uses the correct thread/section.
To your issue then, pull the injectors as thats your ONLY way to find out what they truely are, you should know that already and not need to ask this, to the smoke, it can be your valve stem seals but its most likely down to the turbo seal on the turbine side. these are your first places to check.
Also you are still allowed to post in the newbie section and there are many many threads related to smoke etc with common walk throughs already so my reply was mesrly because you could use our search bar and it will throw alot of threads specific for your needs, that was why my comment was how it was.
Please dont take my replys harshly ok im just trying to do my bit to help the forum out and keep it going the right way for all
thanks man appreciate the help
once I pull the injectors how do I tell the cc? they are rc injectors and I tried looking up the serial number on them to no avail
It might be marked on them but in such a way you cannot see them clearly, worzt case email the numbers you do have to RC
550 are a pretty common small upgrade for the dsm group, the evos are 560 incase you ever come across them and wonder, if your on a 20g then its a bit over kill unless your mid 20psi range and them 550's wont do you any favors, so use this calculator to figure out whats best suited for you injector wise , http://fuelinjectorclinic.com/flow-calculator
again thanks it's only on 10psi also has hks 272 cams and a apexi safc2 which again it's all new to me.i mean this car stock is only 210hp so what would be desired with a 20g turbo and 550cc injectors LOL I will then have to upgrade the fuel pump as well correct?
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
