Fuel injector size
thanx for the link....right now i have a 2.5 inch greddy catback exhaust, k&n intake, greddy bov, fmic, mbc. i'm thinking about upgrading to a evoIII 16g turbo and trying to decide wuts best to go with it.
I would believe a 190 and 550s would suffice and actually max out any 16g. With those(550s) you should be able to get good power to the ground. If the evo has 510s on and gets decent power then 550s should be enough
Andrew
PS I remeber looking at this and from what iot says a upgraded turbo at 17-18 psi with 93 octane all you need is a fuel pump...I have rasied fuel pressure and a pump and I seem to lean out at the top(according to my disco a/f gauge). I would seriously be affraid to run over 15psi on my setup now...but according to them I can run 17-18psi :confused: :confused:
Andrew
You're probably right but I was just thinking about maxing out the injectors while making that kind of power. :dsm:
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
