djssgsx
- 1
- Jul 9, 2006
grants pass,
Oregon
So I did some research on here and I can't find what I'm looking for so I'll ask, So over the weekend I had 90T5I over and we worked on my car and I think we FINALLY figured out what my problem was, we did a boost leak test and it was just blowing all the pressure out of the fuel injector holes. So here is my question, I wen't to NAPA and got a seal kit to replace all the insulators/orings on all my injectors, but I got to looking at it and the tip on the end is different, its probably around an 1/8'' longer than my current ones and has one hole in the end instead of the figure 8 style on my current ones. So did I end up getting the right kit for my application or not and can I make it work? Also that little tip is the only thing that seals it to the head right or do i use another insulator on the bottom too?
Thanks for the help guys.
... The only thing is make sure they are soft.. If not make the softby using some oil...
