General Fuel cut
GORBS88
549
3
May 26, 2004
Oliver, BC, Canada
Hey im looking to find some help as to why im hitting fuel cut. Im running MAFT with 3 inch gm MAF and tuning with tuner pro. Even when i scale the fuel cut back in the program i hit fuel cut anything over 30psi. SO to eliminate that im scaling back my maft on the WOT knob to fool the air flow numbers. BUt then that proves to give timing problems as we all know.
I have NO boost leaks as thats the only thing that i know would cause fuel cut.
Anybody have any insight on this?
Or is DSM LINK in my near future?
thanx
mike
Are you sure it's fuel cut? Have you ruled out the ignition? Checked fuel pressure? Any way of logging I am not familiar with "tuner pro". If you have logs post them up.
thanx
mike
Yes we need more info. Are you running the extended maps? You need to be. Are you sure its fuel cut? Look in the files on the dsm ecu yahoo group. Find the article on extended maps and do it. Then no op the fuel cut code out.
Hey, Yes i know its fuel cut cause i've had it before. And I AM running the exended maps in the tuner pro but seem to have that maxed out too, as im only using the top row now. I cant log as of yet either but its not ignition related or fuel related as when i scale back the MAFT it goes away.
I think its time for DSM link and some speed density.
Im not sure how far guys have pushed tuner pro mabe im at the point where its time to upgrade.?? DYNOED 485 on a mustang dyno so around 550whp on DYNOJET.
ANYONE pushed this program this far? Mabe im just flowing to much air?
thanx
There's two ways to disable fuel cut in the code. The best way is to change the '24' at 559B to '21', which bypasses the fuel cut routine. I've maxed out the extended maps regularly and never hit fuel cut. Make sure you're not getting rich misfires, which can feel like fuel cut.
Honestly if you already use Tunerpro you're less than $100 away from running speed/density with Jackal.
thanx for the advise, Gonna try the new code and see what happens.
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
