fuel cut defender help
dsmking101
224
May 13, 2009
????, Utah
i just got my fuel cut in the mail and installed it i bought it off ebay from someone who makes them he has sold alot and ive herd of good possitive feedback on these fcd's its a little black box with the screw on the side to adjust the volts...dose anyone out there have this fcd if so how did you tune it so your car dosent stutter while approcthing boost or shut off at idle..i have an idea of how to do it because it came with instructions but just want to know if any one has done it before with this fcd and how it turned out .....thanks
Pressurize the intake manifold, so the MAP sensor is reading positive pressure. Use a multimeter and check the voltage leaving the MAP sensor, adjust it till it is in par with the voltage that it's supposed to send out while at atmospheric pressure. I believe that is 4.67v, or something close to that.... :/
Someone else will have to chime in with the exact voltage. I have set one up in quite a while so I don't remember.
thanks that sounds about right i belive its 4.5 or 4.6 volts i need to set it at thanks bro
  • Wanted 6 bolt NT water pipe
    • chrisman287
