fuel cut changing in gears
stevenr816
54
Jan 29, 2009
Phoenix, Arizona
im getting fuel cut at 10-12psi in first and second, 15psi in third and 20+ in fourth and fifth. does this sound right to you? it doesnt to me.
If your experiencing fuel cut at that low of boost pressure I would assume you have a boost leak for starters.
What size of injectors are you using? Fuel managment? Have you confirmed that you are at 100% duty cycle on your injectors and you are in fact experiencing fuel cut?
thanks for that, but that doesnt help at all.
im hitting fuel cut at different boost levels in different gears just like i said
1st & 2nd 10-12psi, 3rd 15-16psi, 4th and 5th 20+psi
i have a 16g, k&n filter, and dejon intake tube. no fuel managment or anything,
my only question is why am i getting fuel cut at different boost levels in different gears?
IMO i would get, bigger injectors/higher psi FP/safc
maybe the stock fuel management cant keep up with the boost levels IMO
my main guess would aim towards weak fuel pump/ not keeping up when the boost kicks in.
or clogged/dirty fuel filter.
