front wheel bearing
bradyc
89
May 14, 2011
meridian, Idaho
Today i started putting the drive-shafts in, the passenger side went on with no problem, but as i started to get working on the drivers side i noticed that the ROTOR has a little play in it. Will this correct itself when i bolt the shaft on? or is this a sign of a failed wheel bearing? Maybe even something else? :|
Yea if there is play in the hub area *were the lug nuts go* if you can wiggle that a decent amount, then yeh your bearing is probaly needing to be replaced.
If there is any play the bearing needs to be replaced...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
