Front Water Pipe Part #
RpVilleneuve
212
7
Jan 31, 2012
glen burnie, Maryland
Ok guys trying to get my new 2g up and running. The PO put a NA front water pipe on the car. I need the water pipe that I can run lines off of for a ball bearing turbo. It's a 6 bolt bottom end and a 7 bolt head. Let me know if anyone has the part # or a link of whereby can find it.
There are still technically 4 variations of that pipe that could fit your application based on what you've told us. I make no claims to availability of the following part numbers as I'm pretty sure the 1990 pipe is obsolete, but I imagine at least the last two are available.
  • 1990 Water Pipe -- MD147684 -- no return port for water-cooled oil cooler, connects to lower radiator hose
  • 1991-1994 Water Pipe -- MD171059 -- with return port from water-cooled oil cooler, connects to lower radiator hose
  • 1995-1999 Water Pipe -- MD306269 -- with return port from water-cooled oil cooler, connects to thermostat housing
There's also MD163195 which is listed for early 1991 models only, but there won't be any difference between an early '91 and a late '91 car so go with MD171059 if that is the one you need.
Hate to bring a dead thread back to life, but I'm looking for replacements for the MD147684 for a 90 GSX. Does anyone know where I can buy a replacement for this? I bought a used one and it appears to be in almost as bad of shape as the one the car came with. Any help is greatly appreciated!
