Nate Crisman
- 749
- 6
- Nov 26, 2008
Blairstown,
New Jersey
I thought I would share pics of the front limit straps I slapped onto my 1g this morning as people often ask about this but don't get much info/pictures.
The strap is simply two of the "crotch belts" from old out of date 5pt harness sets. (you can likely find a set of two of these for free by just walking around the pits at the track and asking, as EVERYONE should have atleast a couple laying around from years past that are utterly useless).
The top L shaped bracket goes to one of the top strut hat studs and is sandwitched between the hat and strut tower. It's made from the pre-drilled strapping steal that's found at pretty much any hardware store. Not 100% sure if this will be strong enough to hold up long term, I might need to go to a thicker steel strap if this stretches or cracks,but only one way to find out I guess.
Top hardware is (2) 8mmx1.25 oem grade 4 bolts & nuts
Bottom hardware is (1) 10mmx1.25 oem grade 7 bolt & nut
But my gut tells me it will be fine.
