Front Mount on 14b?
kpt4321 said:
It's simply that on race gas, the difference is not as large. The difference still sure does exist though!
The point is that is may not generate faster 1/4 times in this extremely specific case (1g, 14b, etc) because the difference is that minimal when you are reaching the end of the 14b.
The whole reason I made the argument that a FMIC may not be necessary because most people in my opinion shooting for best times on 14b are going to be running +20psi and running race gas plus all the basic mods, whereas in Kpt's opinion he would rather take the time/effort/money difference (which may or may not be that significant depending on if it's a DIY, etc) to make gains most of the time.
It was simply a matter of perspective that got blown out of proportion and in the end noone was right or wrong as much as I hate to admit it.
-aaron
I have no problem with your different perspective.
What I do have a problem with is the fact that I made a statement, which was true, and you called me a moron for it. That makes you wrong.
Not only that, but you chose to attack me personally with this crap about misinformation, etc.
Mirage2LTurbo said:
Some stupid can not be learned. I give.
Not true. I'm sure we could help you, if you'd let us try.
Remember when I tried to explain to you that octane does not directly effect burn rate, and you called me an idiot for it? And then, you suggested that I start a thread on NABR about it? Well, I did.
http://www.teamnabr.com/ubbpub/ultimatebb.php?ubb=get_topic;f=10;t=000502
Interestingly enough, the one reply has been one person confirming what I thought.
I have yet to see you prove me wrong, except for where I said "uncompiled" and shortly thereafter admitted I said it accidentally when I meant compiled. That's not stupid, that's a mistake that has been corrected.
If you can find anything else that I said that was wrong I'd love to see it. Good luck.
gsx91boy said:
I am in 100% utter agreement.
In this instance a 14b cannot support it. THAT IS MY ENTIRE POINT.
I'm am simply trying to argue a specific instance, not theory.
-aaron
arron you need to shut the f### up and try and develope a little respect for the wiseman!! in my opinion , and i donnot have to read the rest of your nonsense ,and i think everybody here will agree your a$$ got owned :p
Back to the original discussion . I have a 14b and yes since the front mount intercooler install there has been almost no instances of knock and pulls much harder with only a slight increase in lag.
I wish you guys had not dug this up.
However:
My car with a 14b now has a big FMIC on it. After retuning, the car is much faster. That prove it right there.
Well, since it did get brought up again, I would like to agree with the masses on that one. What would drive a man so mad that you would consider that notion. I know somebody with a t25 that went from his stock ic to an fmic kit, he went from a 14.4 to a 14.2 plus 2 mph. So experience seals the deal.
