Front Camber bolt help
Junkyardspecial
194
May 23, 2011
Affton, Missouri
Noobish question but I have pulled both sides of my cars suspension apart in the front and I am wondering if we have camber bolts? I have copious amounts of positive camber even with my coilovers set to full -2. I have a slight bit of toe in, and cannot see to get an alignment til later this week, wondering, if there are camber bolts if I can adjust them for a small fix til I see the pros. Also is adjusting toe as easy as cranking on the tie rods as in other cars?
Inb4 flame, I hit a deer carcus and it messed my front right wheel up, I readjusted and it came back to where it was after I hit the deer. No bent anything, I got it checked.
Only the rears include camber adjustment. After I lowered mine, I picked up camber bolts to let me fine tune the fronts.
Thanks guys, I guess Ill adjust toe to compensate at the alignment shop, do you guys have links to camber bolts?
