Front AWD LSD and Year ? Pics
willtmcgee
38
Aug 24, 2011
Houston, Texas
Im going to order all the Axle and transfer case seals for my 95 gsx, it has a 6 bolt swap, I just want to make sure the transmission is a 95-99. would a 6 bolt transmission even bolt up?
Also looking thru the axle inputs you can see a pin my friend said it might have an aftermarket diff is that true or is it stock?
That is a 95-99 transmission, the 90-94 transmissions don't have the counter weight on the shift lever and don't have the spot to mount the front and rear roll stops. Also that differential is stock, the pin that you are seeing is what holds the spider gears in place.
