99 gst spyder
- 522
- 1
- Jul 12, 2007
st. paul,
Minnesota
Okay, I'v picked up a free 92 eclipse gsx with a 6bolt motor complete. I opened up everything except internal part and found out the there is some 272 hks camshaft, stock head, mangnus intake manifold, built block with je pistons and eagle rods. A lot of carbon build up on top of piston. Visually, everyone looks okay.
Should I reuse the block and built the head with some springs, retainers, valve stems and seals. What do you guys recommend on parts for the head? What extra work should I change inside the block to make sure everything is still in good condition? Like bearings, main studs, rings, ect......and how do I come about it.
The car was not running but was able to crank. I have another 1g talon I want to swap this motor into that has a complete stock motor.
Thanks a lot.
Thanks a lot.
