FPR Fittings questions
Status
Not open for further replies.
SBstar
3,038
125
Jan 1, 2004
Jackson, Michigan
Alright I'm looking at the Aeromotive Fuel pressure regualtor here are the specs.
The Aeromotive A1000-6 Injected Bypass Regulator was developed for high horsepower EFI applications. Compatible with the Aeromotive A1000 Fuel Pump, this regulator is a cousin to our widely-used A1000 Injected Bypass Regulator, delivering performance, long-life, and reliable operation.
Base pressure (vacuum/boost disconnected) is adjustable from 30 to 70 PSI.
Pump Gas, Race Fuel and Alcohol compatible.
Provides two -6 AN inlet ports and one -6 AN return port.
fuel pressure will rise on a 1:1 ratio when referencing boost.
1/8" NPT gauge port.
Beautifully finished with type II bright red and clear anodized coatings.
Any extra fittings are sold separately.
Is this the fittings I need? I have a 255 lph fuel pump and stock fuel rails.
SBR Fuel Filter (1G / 2G) Bottom Fitting
This is the fitting you need to connect your stock fuel filter to a 6AN feed line.
Do I need anything else. I would really appreciate some help with this. I would get the one designed for the 1G but its out of stock so and i need one an FPR to get my car running.
Status
