2G FP T28 Install snag...Please help
Krmnnghia
125
Jul 30, 2003
Lansing, Michigan
So I have unbolted everything except the hard line running from the top of the stock T25 all the way to the Oil Filter area. Here is my issue. In the middle of that line is a male and female connection. The male end(smaller) is stripped so that isn't coming loose. Can I just Unbolt it over by the Oil Filter and take thewhole piece out? Then I could just unbolt the banjo fitting from the turbo and put it on the new one. THis seems to be my only snag at this point. Any help would be most appreciated. Thanks!
Instead of unbolting it where the two lines meet, You can just unbolt the line from the turbo, And the other end from the oil filter housing, Just make sure you have something under the oil filter housing because oil is going to come out, When you're done. just screw it back in.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
