FP fitment
david-b
562
Aug 15, 2005
Chicago, Illinois
Hey all;
I finally got my car all turboed up and I've been hitting fuel cut. I didn't know that I needed to upgrade my FP. So after searching I'm going to go with a Walbro 190, but do they all fit the same size? I've seen them on eBay for civics, 2g turbos, 1g turbos... how about for the 420a? Same as the 2g turbos? Thanks.
Hey all;
Yup, your good. Just make sure you know if it is inline or in-tank.
The 255 and the 190 are the same price, too.
Paul: Did you change your avatar again?
VelocitàPaola;151536966 said:
All 2G's are in-tank.
Depending on your fuel setup, you might consider a 255lph HP pump instead.
I've got nothing special going on... 12:1 FMU, stock injectors and running 7.25psi on a t3/4
So a 190 won't do the job? I can get a good deal on a 190 and I don't plan on pushing more than what I've got above.
Don't know if makes a difference but I'm using a SAFC to control to.
