fp big 28
turboking15
352
7
Jul 16, 2007
columbus, Ohio
i was just searching looking for a turbo and i cam across the big 28. sounds like a good turbo and i like the quick spoolup. but i was wondering what they use for a turbine housing and wheels. is it something that can be found on other turbos or is it a custom setup??
T28's are a common upgrade on 2g's since they are a direct swap from the t25. They are comparable to a small 16g, but a 16g will bolt up just the same as a 1g's stock turbo, a 14b(what you have). A 16g is much cheaper as well. Something to consider.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
