Found solution to my problems
Ghost_GSX
130
Jan 2, 2011
Hubert, North Carolina
I have not been able to obtain the title for my gsx so my friend brought to my attention about wanting to convert his spyder to awd. In exchange for these parts i would get a titled 2g awd (good deal for both).
So after a few weeks of looking, I am now a proud owner of a 95 eagle talon tsi awd. like all my dsms, this one doesn't run either, and will need alot of tlc.
I know it looks horrible now, but after about $15k she'll be purring.
If we have to, overnight parts from Japan?
It seems like there isn't an engine in it. Are you going to use some parts for your un-titled GSX to get this one running. All he really wanted was the drivetrain right?
That looks like a ton of work good luck it will be worth it.
there is a 7-bolt block and a head in the back hatch
but ill be putting a fully built 6-bolt in this one mostly because ive already bought alot of 6-bolt performance parts
its also been rear ended a bit and the front frame looks bent a li
the only thing im keeping is the lsd from the gsx and the shell (motor and gsx was trashed when i got it so any int. piece i need ill have
