alex99gst
- 1,339
- 24
- Feb 10, 2003
Nashville,
Tennessee
I have searched and I followed this guide: http://www.dsmtuners.com/forums/showthread.php?t=179481
First off, I have my battery relocated to the rear with a 150 amp circuit breaker. I also have the fuel pump rewired, the fans wired up to a 12v switch, and a wideband with the 12v source tapped into the cig lighter. That is the extent of my electrical work.
My test light goes out as soon as I unplug the 40A battery fuse. Is this the drain or would this always happen since it's the battery fuse? I have the positive cable running to a distribution block then to all the other positive connections.
The wideband is only on with the key in the on position, so I don't think that is the problem. The fan switch, on the other hand, has the 12v source wired directly into the distribution block. The switch breaks the connection though, so I didn't think that was it either.
Any help would be greatly appreciated.
I noticed that yesterday, but Defiant's comment makes it even funnier!!
