2G fouling just one single spark plug in cylinder 3
Nick G
May 10, 2015
Lincoln, Nebraska
car runs great for a day or two but constantly fouls plug number 3. I replace it and runs great again. brand new plug wires and is tuned correctly. just can't figure why its just cylinder 3.
Post a pic of said plug.
Fouled by fuel: Injector may be faulty (sticking open)
Fouled by oil: Perform compression test followed by leak-down test to track the issue.
I will take a pic when I get home. It's fouled by oil. The car does 150 compression across the board. But smokes bad. I was thinking rings?
I had a local machine shop do a valve and deck job. I installed it with felt pro head gasket and new arp studs and valve seals. the last thing on the list is rings which explains the smoke. Could I just re ring the pistons by dropping the oil pan or would I have to pull the motor?
