ForcedFour 1G Auto Wiring
vassil
82
May 22, 2002
Winona, Minnesota
Hi Guys,
I am almost done converting my 1G to an auto and have a question about wiring the ForcedFour shiftbox plus. According to the documentation on Shawn's website all I need to run the car without TCU is power, ground, tach output, selenoid A and selenoid B wired. The first three wires are easy. I have no clue where those two selenoids are or what the wires coming out of them are. I took a picture of every possible connector on the transmission:
http://www.bulfab.com/trans.jpg
Can someone tell me which wires are the ones for the the two selenoids?
The car was a manual and still has the manual harness in it. I do have the stock shifter in it to get it into park neutral and reverse.
Hi Guys,
It's the orange and yellow wires at #1 in your picture that control the shift solenoids.
Orange = Solenoid A (connects to yellow wire on shift box)
Yellow = Solenoid B (connects to brown wire on shift box)
Not sure what the blue wire on your trans is for? Mine doesn't have that, unless you've got a 2G tranny and it's for the converter lockup solenoid or something.
Hope this helps ;)
