For a 1g, Only 1 Radiator Fan Kicks On & Off when A/C is Off, Not Both
boosted97gst
37
Jan 25, 2003
Jacksonville, Florida
On a 1g turbo talon/eclipse, is it normal for just 1 radiator fan (passenger side) to kick on and off when the A/C is off? I just wanna know if other 1g owners out there, if thats the case. If thats how they come from the factory. I had a 2g and I know both radiator fans would kick on and off when the a/c was off.
If thats the case that only 1 radiator kicks on and off on a 1g, is it possible to change it so that both fans come on at the same time
This guy is right, but that VAFQ is terible!
I have my ac fan moved to the front of the conderser as a pusher fan now. and in the back of the radiator I have 2 rad fans now.
the #2 fan has its own relay wired directly to the battery with a 30 amp fuse.
I have tapped into the power feed from the #1 fan to act as the energize wire for the #2fans switch side, and now It will turn on and off by itself when the main fan is turned on by the ECU.
The vfaq really isnt what I want to do. I dont have AC as I took the whole AC system off to make room for the FMIC. I dont wanna control the fans with a toggle switch. I can activate both fans by turning the AC button and Fan swith "ON"
I thought about what you did, using a 30 amp relay and splicing the activation switch into the #1 radiator fans power wire. I guess I will have to go that route.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
  • For sale FIC 1220 Injectors AEM 320lph fuel pump with rewire kit
    FIC 1220 Injectors AEM 320lph fuel pump with rewire kit. 450 shipped to the lower 48 states.You...
    • elocneas
  • For sale 4G63 Bastard 20g
    Bastard 20g turbo Like New
    • arodgst
  • For sale 2g 97 GSX part out
    Ex-wife's project car part-out. Will be updating the list over the next few weeks and adding...
    • Type1DSMr
