fmic install now fuel cut at wot. What is this for ?
burldude
200
May 2, 2004
Fort Bragg, California
I just got done installing my fmic . I ran into one prob, the the first section of boost pipe from the compressor housing has a 1/8 inch pipe coming out from it an I do not have that on my new kit . What does this little thing do . Iam assuming that it is very much needed. With it disconnected I am now pulling 14 lbs of boost . Is this just from the new hard pipe or is this becuase waste gate is opening later, or not at all . Iam a little confused . I have an safc on the way should be here monday . I am sure I am going to need some more fuel . I had one spike of knock count around 46. Iam not running around with it like this it just showed up under full throttle . As long as I dont hit 6500 rpm I can drive pretty aggresive . The fmic deffinetly added some hp and torque ,even down low.
Well I guess I was out in the sun to long with no water I read my post now and I think what a moron . Any way larger injectors and fuel pump a must .
    • george bromwell
    • pma1123
    • Sdcryan1
