Flex fan not turning on???
Status
Not open for further replies.
98gstshadow
70
Sep 26, 2004
College Station, Texas
hey guys My problem is that my newly installed fan the flex a lite, used to work for a couple weeks so I know my wiring was correct well I was installing my stereo and I accidently sparked the wire in the engine bay against the block, well after that the fan didnt turn on again, the condensor fan is working fine, ok so I checked all 3 relays in the fuse box and none of them are getting signal, I also put a fuse between the fan and the fuse box and its fine, so im wondering what is there between the fuse box and the battery besides the cables that could have popped?? maybe its my cables?? any adivce guys?
come on please I cant drive my car anywhere with out it overheating pleaseeeeee gimme some help or at least some ideas that i can go on I dont want to take it to the devil,
Did u use a voltage tester on the wires to the fan and if so then look at the wires from where they come out to the battery and see if maybe they got cut or whatever. or just check all fuses that might have to do with the fan. hopefully that will help you
Status
