Flat rate time to change timing belt?
Chris89lx
Sep 23, 2004
Calgary, Asia
Does anyone know the flat rate time for changing a timing belt and tensioner on a 1993 Eagle Talon AWD turbo?
How are they to do and how long does it actually take.
Any tips or secrets?
Thanks.
It only takes me about an hour and a half. If you find some parts that need replacing or encounter bolts that don't want to come loose due 2 corrosion, then it could take ALOT longer. Make sure that you have a repair manual. PAY ATTENTION THE TORQUE SPECS FOR EVERY SINGLE BOLT. If you don't use a torque wrench to torque down everything to spec, something will come loose and you will crush all your valves.
