Road-Rocket
- 201
- 0
- Mar 8, 2003
Escondido,
California
DSMvroom said:...one thing i noticed is that the flange that mates up to the head relative to the flange that mates up to the turbo is not at a 90 degree angle. I don't know if it is supposed to be that way or not but I presumed they would be at a 90 degree angle.
It's not supposed to be at a 90 degree angle. I think it's more like 85 or 80. May be even less. I noticed that too in my SBR manifold. And when the stocker came out, same thing. In fact, I have the stocker sitting right next to me and it's not 90 degrees relative to the head flange. You'll be fine as long as the product was built correctly. Just make sure the flanges are completely flat. As I mentioned before, the flange in my o2 housing was warped. Also have a file or some kind of grinding tool available just in case the bolt holes don't line up with the turbine housing or the head studs. I really hope this works for you. If it does and lasts more than a few months, I might consider getting the mani. When are you going to install it? Good luck and keep us posted.
some of which trap 115+
comon I jerk off
to porn on here
