fixing someone elses problem...arrgghhh
Below Ambient
633
5
May 24, 2003
Methford, Oregon
ok so i bought my 90 GSX a few months ago and have been slowly fixing all the problems... it didnt have a BISS screw when i got it so i got one of those and then the ISC was unplugged and the harness was cut so i fixed that, but after connecting the ISC and rewiring the wires so i could have a throttle stop it wont idle at all... probably a reason for that the harness was all cut up?
anyways it misses like crazy at idle and it'll idle great sometimes, but other times itll just fluctuate like crazy in 2 different modes... 1000-1500rpm and 500-1000 rpm... the second mode itll fluctuate twice then die... then sometimes itll die altogether like when i come off the freeway or after any kind of sustained speed...
I tried 2 different ics's and went through the Vfaq and both ISC's check out fine...
this leads me to beelive that perhaps i missed some kind of possibility that neither the throttle stop or ISC are adjusted properly..
any other ideas? take into consideration that this is a 90 model so it doesnt have a TPS...just the throttle stop and ISC..
thanks in advance... -Matt
Pressurize the intake and check for leaks. Run a compression check. All the normal stuff.
Of course '90s have a TPS. Are you sure yours is missing? Did the PO hack that off too?
Steve
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
