First time @ Track
BMWHATR
251
Jun 1, 2004
Chicago, Illinois
97 GST
Ok so i went to the track couple weeks ago and i ran 4 times and the best time was
15.8 lunched @ 3,100RPM
My mods
3" Apexi N1 exust no cat
thats it. evrything els stock.
Turns out my blow off valve was holding only 8psi and was leaking.
Just want to know what can i get if i would have:
Forge bov
T-25 @14psi
same exust
@ what RPM u guy take off?
That looks like a pretty good time with your mods, especially being your first time out. 60ft. is pretty decent. Get the BOV fixed and raise the boost a little, low 15's/high 14's shouldn't be a problem. :thumb:
I think the MPH looks a little low. Have you done normal maintenance items? I might would check for boost leaks. My car trapped 71 in the 1/8 bone stock down to the airbox and BCS.
I blew a turbo after the track! and it showed me i was only boosting 9psi on avrage. I thinik my blow off valve was done. but now since i replaced it i started to get boost spikes at first about 18psi on higher gears
Thats a good 330!!!
