first logs, and some questions...
xcelr8n
1,854
5
Jan 31, 2003
toronto,
hey guys, i got some quick logs to post, hopefully someone can help me out with a couple things... i'm pretty sure the logs are ok, but my trims arent...
RPM KNOCK TIMA 02 TPS
3300 0 15* .96 77%
3600 0 16* .96 100%
4300 2 17* .96 100%
4900 1 20* .94 100%
5500 1 19* .94 100%
6400 2 17* .94 100%
and my trims are as follows..
Low - 140%
Mid - 105%
High - 85%
any ideas on how to make those better...
thanks guys.
3300 0 15* .96 77%
3600 0 16* .96 100%
4300 2 17* .96 100%
4900 1 20* .94 100%
5500 1 19* .94 100%
6400 2 17* .94 100%
Low - 140%
Mid - 105%
High - 85%
thanks guys.
lows are idle, mess around with them on the fly, get your pocketlogger out, and look at your percentages change with changes to the safc, richen things up in low throttle and see if it gets worse or better, if it gets better, continue on, if it gets worse (higher percentage), lean them out, usually in low throttle, its pretty stable to keep every rpm point the same. your mid fuel trim is near perfect and doesnt need adjusting. your high does need adjusting, again, richen up at 4, 5, and 6 and see what happens, if it worsens, lean it a little. if i were you, i would use +/-1% increments at a time on the safc.
I dont have an safc, I have a maf-t.... but youre advice is still appreciated, as the maf-t has the same general principals.
thanks
is there a tuning guide for the pocketlogger?
what guidelines should we follow?
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
