ECMlink First logs with fic750s and TD05H 20G. Some issues.
DSMTyson
1,225
10
Nov 9, 2010
Lake Charles, Louisiana
These are the first logs since I have installed my new(used LOL) fic 750cc injectors and my new TD05H 20G.
I am running wastegate pressure for obvious reasons.. I have left everything the same as it was when I had taken the 14b off(DA tables) and I zeroed out the maf(had a boost leak on the chra of the 14b), exept I adjusted the fuel table a bit so that I wasn't running really lean when in boost. I think it was in log 4 or 5 when i adjusted it.
My o2 sensor is not cycling for some reason, it is a brand new bosch o2 sensor for a 91 eagle talon tsi. It doesn't even cycle while in narrowband sim . Any suggestions that could fix this issue? or is it probably defective?
I run lean on hot starts and when I have my foot on the brake, AND when i'm idling lower than 1000 rpm. I'm thinking its a vaccum leak, what do you think? Or maybe my alternator??
Looking for pointers.
log.2011.04.26-02.elg (log 2)
log.2011.04.26-03.elg (log 3)
log.2011.04.26-04.elg (log 4)
log.2011.04.26-05.elg (log 5) Knocking like crazy around 260 seconds. Pretty scary.....
Just click the download thing..
34 views and 0 replies? come on guys.
