first log
talon_frost
194
Feb 10, 2008
Kitchener,
hey guys this was my first log tell me what you think and give me some advice on how to make it beter thanks....:thumb:
sorry it wont let me load the pic of the log but i can PM anyone whos askes thanks.... actually ill just tell you what they were
42 counts of knock on 90 % injector duty cycle
throttle position at 88.8 percent
fuel trim 100%
37 timing advanced
thats what my graph was telling me at wot, but i know there is something deffinatly wrong
Timing should not be that high at WOT, the most you should get is about 22 from the stock timing map.
How much boost?
When was the last time you replaced the knock sensor?
What did your O2v read?
What program are you using to log?
Do you ever get 100% TPS reading?
Does your TPS read 10% at idle?
about a year or so ago give or take a couple of months.. for the knock sensor and im running 15 psi 02 reading was 0.87 and no never got 100% tps reading and yes its at 10 % when idle. the program I used for the graph was hand held halo data logger.
I would try to adjust your throttle cable or TPS so that it reads a full 100% at WOT and 10% at idle. Start there.
Also, check for boost leaks.
A full WOT log from 2500rpm to redline would be great if you could post it.
sure ill do that in the morning, after I do a dlt and adjust the throttle cable. then ill post some more info..thanks
If your throttle cable won't adjust far enough, you might have the same problem as me, which was a bent accelerator arm. If you have cruise, sometimes you'll get some binding in that box too. Hopefully it saves you some head scratching :thumb:
ok ive adjusted my throttle to 10.5 % at idle but at wot i cant get it to 100% just 96% am i doing something wrong?
