first log
talonproject
101
Jun 27, 2005
somewhere happenning,
hey guys
i didn my first log today
i would ve liked to post it in the logging section but i m still restricted
i m still confused a bit with all these values so tell me what u think
my mods:
evo3 16g at 10psi
2.5 turbo back
2.5 UICP
2.5 O2 housing
act 2100 clutch + flywheel
walbro 255 rewired
BS removed
guess that s about it for now
i know i need injectors and a safc....actually if som1 has some for sale i d be glad to buy them
ERPM KNCK TIMA O2-R FTRL FTRM FTRH
3093.75 2.00 31.00 0.29 139.62 99.06 81.12
3187.50 14.00 25.00 0.84 139.62 99.06 81.12
3281.25 41.00 2.00 0.96 139.62 99.06 81.12
3343.75 42.00 -3.00 0.96 139.62 99.06 81.12
3437.50 41.00 -2.00 0.96 139.62 99.06 81.12
3562.50 39.00 -1.00 0.96 139.62 99.06 81.12
3687.50 38.00 -1.00 0.96 139.62 99.06 81.12
3781.25 37.00 1.00 0.96 139.62 99.06 81.12
3843.75 36.00 0.00 0.96 139.62 99.06 81.12
4000.00 35.00 1.00 0.94 139.62 99.06 81.12
4093.75 34.00 1.00 0.94 139.62 99.06 81.12
4093.75 32.00 1.00 0.94 139.62 99.06 81.12
4250.00 32.00 2.00 0.94 139.62 99.06 81.12
4343.75 31.00 2.00 0.94 139.62 99.06 81.12
4406.25 30.00 1.00 0.94 139.62 99.06 81.12
4625.00 29.00 1.00 0.94 139.62 99.06 81.12
4656.25 27.00 1.00 0.92 139.62 99.06 81.12
4718.75 26.00 2.00 0.92 139.62 99.06 81.12
4781.25 25.00 3.00 0.92 139.62 99.06 81.12
4875.00 24.00 3.00 0.92 139.62 99.06 81.12
4875.00 23.00 3.00 0.92 139.62 99.06 81.12
4968.75 22.00 4.00 0.92 139.62 99.06 81.12
4968.75 22.00 5.00 0.92 139.62 99.06 81.12
5000.00 21.00 5.00 0.92 139.62 99.06 81.12
5062.50 20.00 5.00 0.92 139.62 99.06 81.12
5218.75 19.00 6.00 0.92 139.62 99.06 81.12
5250.00 18.00 6.00 0.92 139.62 99.06 81.12
5437.50 17.00 7.00 0.92 139.62 99.06 81.12
5468.75 19.00 7.00 0.92 139.62 99.06 81.12
5468.75 18.00 6.00 0.92 139.62 99.06 81.12
5500.00 17.00 7.00 0.92 139.62 99.06 81.12
5593.75 17.00 7.00 0.92 139.62 99.06 81.12
5625.00 16.00 7.00 0.92 139.62 99.06 81.12
5656.25 15.00 9.00 0.92 139.62 99.06 81.12
5781.25 14.00 9.00 0.92 139.62 99.06 81.12
5906.25 13.00 9.00 0.92 139.62 99.06 81.12
5781.25 12.00 10.00 0.92 139.62 99.06 81.12
5968.75 11.00 10.00 0.92 139.62 99.06 81.12
5906.25 10.00 10.00 0.92 139.62 99.06 81.12
5968.75 9.00 12.00 0.92 139.62 99.06 81.12
5906.25 8.00 12.00 0.92 139.62 99.06 81.12
Inj duty : 97.6 % at 5968.75 rpm
So looks like i have a lot of knock :cry: but sometimes when i floor it i get 0 ? My lifters are sometimes pretty noisy..
also why is it that my Fueltrimlow are at 139% ?
any advices?
thanx a lot
oh wow you have problems. Only 12 deg advance. Add more fuel. If you dont want to push stock injectors, get alky/water injection. Will help you out alot, or upgrade injectors.
Sounds like me and you have the same problem im only getting like 13 deg of timing. and my car just feels like it falls on its face. Ive tried adding fuel to mine like they said above but it didint help. Im going to check my timing to see what its at. They say best is around 5deg base timing. so you might want to check it. Mines not adjustable but your lucky yours is. Hopefully somebody will give you some good advice and it will help us both. If you figure it out let me know please.
are you hitting fuel cut?
Nope, well not until 6krpm, i haven t pushed it yet after that
actually sometimes i get no knock at all on a hard 2nd or 3rd gear pull
I ll go check out my timing tomorrow...
and i guess i ll do a best leak test as well..
