First Log Any response appreciated.
lownslow2002
Mar 11, 2005
Manhattan, Kansas
So here it is this is on a 14b with 20 psi walboro 255lph 550cc injectors FMIC
TPS TIMA RPM KNCK O2-R
63.1% 27° 3813 0 0.84V
71.0% 25° 4031 0 0.88V
77.6% 20° 4125 0 0.88V
85.1% 17° 4313 0 0.88V
100.0% 16° 4531 1 0.86V
100.0% 16° 4750 0 0.86V
100.0% 18° 5031 0 0.86V
100.0% 19° 5250 0 0.86V
100.0% 20° 5313 0 0.86V
100.0% 21° 5594 0 0.86V
100.0% 22° 5750 0 0.86V
100.0% 25° 5781 0 0.86V
100.0% 26° 6000 0 0.86V
100.0% 27° 6125 0 0.86V
100.0% 25° 6219 0 0.86V
100.0% 25° 6344 0 0.86V
89.4% 26° 6500 0 0.86V
TIMA O2-R RPM KNCK
26° 0.88V 3656 0
24° 0.90V 3781 0
20° 0.90V 3906 0
17° 0.90V 4094 0
16° 0.90V 4250 0
16° 0.90V 4563 0
16° 0.90V 4750 0
17° 0.88V 4969 0
17° 0.88V 5156 0
19° 0.88V 5406 0
20° 0.88V 5625 0
21° 0.88V 5719 0
22° 0.88V 5875 0
25° 0.88V 6000 0
25° 0.88V 6156 0
25° 0.88V 6313 0
24° 0.88V 6344 0
23° 0.90V 5906 0
thats a lot of TIMING ADVANCE it seems liek your 02 is low but you are not gettin knock
how does hte car perform. it seems okay cept for was this on race gas or pump.. it doesnt seem right ot have that much timming advance maybe im worng but it looks okay other than the 02 being a little low
Its on pump gas and I agree that Is a ton of timing advance compared to others. Does anyone have an Idea on how to get that advance down?
try adding some fuel from 5500 to redline. since thats whre you stat to get over 21 degrees of timming that should richen up your 02's also to around .92v where they should be
Well you can add boost, which will lower the timing. Liquordrunks log looks perfect, why would you want to lessen the timing, timing makes power. You can also retard the base timing. I would just add boost to be honest and see if you still get any knock. .88 on the O2s is excellent.
Dont push the 14b past 20psi...I think thats quite good dont you. If you were only running 15 psi this would be a differen story but we dont want to go out of the efficiency range of the 14b. id say your running pretty damn good. I bet that car feels great when you launch. Have fun!
I just ordered a TO4B for the car. I am going to install it with my new intake and I ordered all new vacume hoses and a new exhaust gasket. I hope that my 550 injectors will hold out for a little while. Cant wait to feel the difference between it and my 14b. Thanks for all the responses here is my latest log from today.
100.0% 3688 0.84V 29° 0
100.0% 3875 0.88V 26° 0
100.0% 4094 0.88V 22° 0
100.0% 4313 0.88V 18° 0
100.0% 4531 0.86V 18° 0
100.0% 4781 0.86V 18° 0
100.0% 4969 0.86V 19° 0
100.0% 5156 0.86V 19° 0
100.0% 5313 0.86V 20° 0
100.0% 5438 0.86V 21° 0
100.0% 5656 0.86V 22° 0
100.0% 5750 0.86V 24° 0
100.0% 5875 0.86V 27° 0
100.0% 6000 0.86V 29° 0
100.0% 6188 0.86V 28° 0
100.0% 6344 0.86V 28° 0
100.0% 6406 0.86V 27° 0
100.0% 6531 0.86V 27° 0
Does the timing decrease because the efficency of the turbo decreases at that high of boost at above 6000 rpms.
Turn the boost up.. i seen my buddy personally run a 14b at 25lb on a supra side mount. i say if your not getting knock keep leaning it out or turning the boost up
eclipse :dsm: talon :talon: laser :laser:
The stock ecu timing map is set to decrease timing up top. I would definitely add more boost with that timing. I would ad a few lbs and see where your timing and knock is. I say if you can get 21-23 degrees up top with no knock then thats where the boost should be set at. You have plenty of room for more boost, so turn it up!
Wait a minute. Am i the only that realizes this guy probably has a stock head gasket. At 21psi on a 14b, I'd say thats enough, maybe 2 more if ported and clipped. Prevention or cure. Your choice!!
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
