First Logs, any help would be appreciated
BlackbirdOfPrey
435
Dec 4, 2003
Shiloh,
I did this run set at about 14 Psi, I also did another log that looked really similar. Any help figuring out why my knock shot up would be helpful along with explaining some of the other weird numbers. BTW is it odd that my fuel trims are all at 130% +?
TIMA O2-R MAFS RPM KNCK
30° 0.82V 257.9Hz 2250 0
30° 0.18V 257.9Hz 2313 0
30° 0.76V 264.2Hz 2375 0
30° 0.72V 270.5Hz 2406 0
30° 0.25V 283.1Hz 2469 0
30° 0.20V 283.1Hz 2500 0
30° 0.84V 289.3Hz 2563 0
30° 0.20V 346.0Hz 2625 0
27° 0.92V 465.5Hz 2688 0
25° 0.14V 534.7Hz 2813 1
21° 0.92V 647.9Hz 2938 0
18° 0.96V 805.1Hz 3125 0
15° 0.96V 993.8Hz 3313 0
15° 0.96V 1119.6Hz 3563 0
16° 0.94V 1276.9Hz 3781 5
13° 0.94V 1352.4Hz 4031 25
9° 0.92V 1497.0Hz 4313 43
3° 0.94V 1559.9Hz 4531 43
3° 0.92V 1604.0Hz 4719 42
4° 0.92V 1604.0Hz 4906 41
4° 0.92V 1604.0Hz 5063 41
5° 0.92V 1604.0Hz 5250 41
7° 0.92V 1604.0Hz 5375 43
6° 0.92V 1604.0Hz 5531 42
7° 0.90V 1604.0Hz 5656 42
8° 0.90V 1604.0Hz 5781 41
8° 0.90V 1604.0Hz 5875 40
9° 0.90V 1604.0Hz 5938 43
9° 0.90V 1604.0Hz 6156 42
8° 0.90V 1604.0Hz 6156 42
7° 0.90V 1604.0Hz 6344 42
6° 0.88V 1604.0Hz 6406 41
7° 0.88V 1604.0Hz 6500 41
6° 0.88V 1604.0Hz 6594 40
6° 0.88V 1604.0Hz 6656 39
5° 0.88V 1604.0Hz 6688 39
5° 0.88V 1604.0Hz 6875 38
4° 0.88V 1604.0Hz 6813 37
5° 0.86V 1604.0Hz 7063 37
5° 0.86V 1604.0Hz 7000 36
6° 0.86V 1604.0Hz 7125 37
6° 0.86V 1604.0Hz 7063 37
6° 0.86V 1604.0Hz 7219 36
6° 0.86V 1604.0Hz 7156 35
Looks like your going lean at 3700 and up....if you are on a stock turbo and fuel system, i would check everything to do with fuel. (filter, pump, injectors, etc) Are you sure you are not boosting higher than 14? Maybe rewire your pump if stock?
I am on the stock turbo, stock fuel (everything, pump, injectors etc....) and it is holding 14psi solid, not even spiking on initial boost. Is 14 psi too much? I was told I should be able to run up to 15 without running too lean. At Idle should my low fuel trims be at 130%? or is that an indication of a problem, that seems a little high.
14 should be fine. If everything is stock aside from your k&n and mbc, I would suggest a new fuel filter. Does you car idle fine? how about just normal driving? highway cruising? If it does ok at those times and just screwy at wot, then i would say its probably your fuel filter. Maybe your injectors are really dirty. I would think one of the two.
just a tip... leave the fuel filter on the firewall when you break the connections loose.. or you'll be sorry.. hehe.. i'm speaking from experience, i am now looking for a double flare tool
LOL....same here....loosen the bolts before taking the bracket off....damn i cussed ALOT!!!! :mad:
You might even need a longer handled wrench to get that thing off. Also, it's a good idea to put some thread tape on the lower fuel line fitting. It's a lot easier when the battery is out than trying to fix a leak after startup. Also if you can hook up power to the system, do a fuel pump startup with the logger and presureize the system bofrore sticky the brick back in. By brick I mean the massive chunk of battery most of us have. Let us know if the situation improves. By the way, when does the MAS run out of reading room? I noticed that the readings on the above log stopped pretty much at 1600Hz. How far does the stock meter go? Just a thought.
1600 is all the logger can read. the actual number the ecu sees is much higher. log injector pulse as well. You would think it was lean because of the knock, but his o2 volts are fine. .86 is not very lean at all. That's about what i run when im fully tuned with zero knock. But dont tune to just o2 volts. I agree with the fuel filter theory. I changed mine the other day. couldn't even blow air through it, changed the filter, and voila, back to runnin 12's again.
oh yeah, dont let them scare you with the filter change. If you have to cuss and swear, and take more then 10minutes of your time, then there is something wrong with you. If you cant get the banjo bolt off the top, take the whole damn thing out with the fuel line to the fuel rail, put the filter in a vise, and crack that s.o.b. off. and get double flare wrench too, much nicer.
the bottom one is harder.. because it's so difficult to get to
it's not extremely hard, though
and you're working on a gen1... we're gen2.. gen2 is much harder than gen1...
I did a few more logs today This one is at 10 Psi
O2-R TPS MAFS RPM KNCK INJP
0.70V 22.4% 226.4Hz 2875 0 4.35ms
0.84V 54.9% 465.5Hz 2969 0 7.94ms
0.88V 79.2% 603.8Hz 3125 1 9.22ms
0.92V 82.0% 773.7Hz 3281 0 12.80ms
0.94V 84.7% 981.2Hz 3469 0 15.36ms
0.92V 85.5% 1044.1Hz 3656 1 15.10ms
0.92V 86.7% 1138.5Hz 4000 0 15.62ms
0.92V 87.8% 1220.3Hz 4188 0 15.87ms
0.92V 88.2% 1239.1Hz 4406 0 15.87ms
0.92V 88.6% 1339.8Hz 4656 0 16.38ms
0.92V 89.4% 1390.1Hz 4875 4 16.13ms
0.92V 89.8% 1434.1Hz 5094 3 16.13ms
0.92V 90.2% 1503.3Hz 5281 3 16.38ms
0.92V 90.2% 1572.5Hz 5500 8 16.64ms
0.92V 90.6% 1604.0Hz 5594 7 16.38ms
0.92V 90.6% 1604.0Hz 5719 15 16.38ms
0.92V 90.6% 1604.0Hz 5938 14 16.13ms
0.92V 90.6% 1604.0Hz 6063 13 16.38ms
0.90V 90.6% 1604.0Hz 6125 13 16.13ms
0.90V 90.6% 1604.0Hz 6219 19 16.13ms
0.90V 91.0% 1604.0Hz 6375 18 16.13ms
0.90V 91.4% 1604.0Hz 6531 19 16.13ms
0.90V 91.8% 1604.0Hz 6625 18 15.87ms
0.90V 92.2% 1604.0Hz 6594 18 15.62ms
0.90V 92.2% 1604.0Hz 6719 18 15.62ms
0.90V 92.5% 1604.0Hz 6781 17 15.62ms
0.90V 92.5% 1604.0Hz 6906 16 15.36ms
0.90V 92.5% 1604.0Hz 7000 16 15.10ms
0.90V 92.5% 1604.0Hz 7156 15 14.85ms
0.90V 93.3% 1604.0Hz 7094 14 14.59ms
0.90V 93.7% 1604.0Hz 7188 15 14.34ms
0.90V 93.7% 1604.0Hz 7281 14 14.08ms
0.90V 93.7% 1604.0Hz 7313 14 13.82ms
And this one at 12 PSI
0.74V 31.8% 289.3Hz 2531 0 6.40ms
0.64V 65.5% 434.0Hz 2594 0 8.19ms
0.94V 83.1% 509.5Hz 2719 0 8.45ms
0.92V 84.7% 591.3Hz 2844 0 9.73ms
0.94V 85.9% 691.9Hz 3000 0 12.03ms
0.96V 86.7% 842.9Hz 3188 0 14.34ms
0.96V 86.7% 1012.7Hz 3406 0 16.13ms
0.96V 87.1% 1069.3Hz 3656 0 15.87ms
0.94V 87.1% 1113.3Hz 3781 0 15.62ms
0.94V 87.1% 1245.4Hz 4094 6 16.38ms
0.94V 87.1% 1295.7Hz 4281 5 16.64ms
0.96V 87.1% 1390.1Hz 4563 4 16.90ms
0.94V 87.1% 1453.0Hz 4750 3 17.41ms
0.94V 87.1% 1509.6Hz 4938 9 17.15ms
0.94V 87.1% 1585.1Hz 5156 13 17.41ms
0.94V 87.5% 1604.0Hz 5313 12 17.41ms
0.94V 87.8% 1604.0Hz 5438 15 17.15ms
0.94V 88.2% 1604.0Hz 5594 18 17.15ms
0.94V 88.6% 1604.0Hz 5813 21 17.15ms
0.92V 89.0% 1604.0Hz 5875 21 17.15ms
0.92V 89.0% 1604.0Hz 6094 20 16.90ms
0.92V 89.4% 1604.0Hz 6125 19 16.90ms
0.92V 89.4% 1604.0Hz 6250 19 16.90ms
0.92V 90.2% 1604.0Hz 6375 18 16.90ms
0.92V 90.6% 1604.0Hz 6375 17 16.64ms
0.92V 91.0% 1604.0Hz 6438 17 16.64ms
0.92V 91.4% 1604.0Hz 6656 16 16.38ms
0.92V 91.8% 1604.0Hz 6688 15 16.38ms
0.92V 91.8% 1604.0Hz 6875 17 16.38ms
0.92V 91.8% 1604.0Hz 6969 16 16.13ms
0.90V 92.2% 1604.0Hz 6938 15 15.87ms
0.90V 92.2% 1604.0Hz 7094 15 15.62ms
0.90V 92.2% 1604.0Hz 7156 15 15.36ms
0.90V 92.2% 1604.0Hz 7094 14 15.36ms
0.90V 92.2% 1604.0Hz 7125 14 15.10ms
0.90V 91.8% 1604.0Hz 7281 13 14.85ms
0.90V 92.2% 1604.0Hz 7313 12 14.59ms
I still seem to be knocking at upper rpms, now that I've eliminated overboosting, anyone else have suggestions. One other thing I noticed is that if I set it for 12psi, once I got to about 6k the boost would drop slowly down to about 10psi and hold, is this normal?
