First Log....any advice...
selser420
83
Apr 8, 2005
Detroit, Michigan
This is my first log and I was wondering if anyone has any advice. I was running 13-
15lbs of boost on 94 octane.
SECOND GEAR
ERPM  TIMA O2-R KNCK TPS INJP
2156.25  35.00 0.66 0.00 18.43 2.56
2156.25 35.00 0.14 0.00 18.43 2.56
2187.50 35.00 0.27 0.00 18.43 2.56
2187.50 35.00 0.78 0.00 18.43 2.56
2218.75 35.00 0.74 0.00 18.43 2.56
2218.75 35.00 0.49 0.00 18.43 2.56
2218.75 35.00 0.18 0.00 18.43 2.56
2250.00 35.00 0.14 0.00 18.82 2.56
2281.25 35.00 0.62 0.00 25.10 3.84
2343.75 33.00 0.12 0.00 27.45 4.61
2375.00 31.00 0.41 0.00 27.45 4.61
2406.25 31.00 0.82 0.00 27.45 4.61
2468.75 31.00 0.80 0.00 27.84 4.61
2500.00 30.00 0.76 0.00 27.84 4.61
2562.50 30.00 0.66 0.00 27.84 4.61
2593.75 30.00 0.29 0.00 27.84 4.86
2656.25 30.00 0.33 0.00 27.84 4.61
2687.50 31.00 0.78 0.00 27.84 4.61
2750.00 31.00 0.66 0.00 27.84 4.61
2812.50 32.00 0.14 0.00 27.84 4.86
2843.75 32.00 0.43 0.00 27.84 4.86
2906.25 32.00 0.82 0.00 27.84 4.61
2937.50 32.00 0.72 0.00 27.84 4.35
3000.00 32.00 0.27 0.00 27.84 4.61
3031.25 33.00 0.27 0.00 27.84 4.61
3062.50 34.00 0.76 0.00 27.84 4.61
3125.00 34.00 0.55 0.00 27.84 4.61
3187.50 34.00 0.18 0.00 27.84 4.61
3218.75 34.00 0.80 0.00 27.84 4.35
3250.00 34.00 0.53 0.00 27.84 4.61
3312.50 34.00 0.33 0.00 27.84 4.35
3343.75 34.00 0.76 0.00 27.84 4.35
3406.25 34.00 0.20 0.00 27.84 4.35
3437.50 34.00 0.45 0.00 27.84 4.35
3437.50 34.00 0.80 0.00 27.84 4.35
3531.25 34.00 0.66 0.00 28.24 4.35
3593.75 34.00 0.10 0.00 36.08 5.63
3687.50 30.00 0.04 0.00 54.12 8.45
3812.50 26.00 0.90 0.00 78.43 10.24
3968.75 25.00 0.92 2.00 90.20 12.54
4062.50 21.00 0.92 2.00 90.59 15.10
4156.25 17.00 0.94 1.00 90.98 16.90
4312.50 17.00 0.94 1.00 90.98 17.41
4468.75 17.00 0.94 1.00 91.37 17.15
4562.50 17.00 0.94 1.00 91.37 16.90
4687.50 17.00 0.94 0.00 91.37 17.15
4812.50 19.00 0.94 0.00 91.37 17.66
4937.50 19.00 0.94 0.00 91.37 17.92
4937.50 20.00 0.94 0.00 91.37 18.43
5062.50 20.00 0.94 1.00 91.37 17.92
5250.00 21.00 0.94 1.00 91.37 18.18
5375.00 21.00 0.94 1.00 91.37 17.92
5406.25 22.00 0.94 1.00 91.37 17.92
5500.00 22.00 0.94 0.00 91.37 17.66
5593.75 24.00 0.94 0.00 91.37 17.41
5687.50 24.00 0.94 0.00 91.37 17.66
5812.50 23.00 0.94 0.00 91.37 17.66
5937.50 23.00 0.92 0.00 75.69 17.41
5968.75 22.00 0.94 1.00 38.43 5.63
6125.00 36.00 0.92 0.00 10.20 1.28
6218.75 45.00 0.72 0.00 10.20 1.79
6312.50 45.00 0.74 0.00 10.20 1.54
THIRD GEAR TIMA O2 KNOCK TPS INJP
4218.75 25.00 0.92 1.00 100.00 12.54
4343.75 22.00 0.92 1.00 100.00 15.62
4375.00 17.00 0.94 0.00 100.00 17.15
4437.50 17.00 0.94 0.00 100.00 16.64
4562.50 17.00 0.94 0.00 100.00 16.38
4593.75 17.00 0.94 0.00 100.00 16.38
4656.25 17.00 0.94 0.00 100.00 16.64
4718.75 17.00 0.94 0.00 100.00 17.15
4812.50 18.00 0.94 0.00 100.00 17.41
4906.25 18.00 0.94 0.00 100.00 17.15
4906.25 18.00 0.94 0.00 100.00 17.41
5000.00 18.00 0.94 0.00 100.00 17.41
5093.75 18.00 0.94 0.00 100.00 17.41
5187.50 19.00 0.94 0.00 100.00 17.41
5187.50 19.00 0.94 0.00 100.00 17.66
5218.75 19.00 0.94 0.00 100.00 17.66
5343.75 20.00 0.94 0.00 100.00 17.66
5312.50 20.00 0.94 0.00 100.00 17.66
5375.00 20.00 0.94 0.00 100.00 17.66
5468.75 20.00 0.92 0.00 100.00 17.66
5562.50 21.00 0.94 0.00 100.00 17.41
5531.25 21.00 0.92 0.00 100.00 17.41
5718.75 22.00 0.92 0.00 100.00 17.41
5656.25 22.00 0.92 0.00 100.00 17.41
5781.25 22.00 0.92 0.00 100.00 17.15
5843.75 22.00 0.92 0.00 100.00 17.15
5875.00 23.00 0.92 0.00 97.65 17.15
5875.00 23.00 0.92 0.00 96.86 17.15
5937.50 23.00 0.92 0.00 96.47 17.15
5875.00 21.00 0.92 4.00 96.08 16.90
6031.25 21.00 0.92 4.00 95.69 16.90
6156.25 21.00 0.92 4.00 95.69 16.90
6062.50 21.00 0.92 3.00 95.69 17.15
6156.25 22.00 0.92 4.00 95.69 16.90
6218.75 20.00 0.92 4.00 95.69 17.15
6187.50 20.00 0.92 4.00 95.69 16.90
6281.25 20.00 0.92 4.00 95.69 17.15
6343.75 18.00 0.92 3.00 95.29 17.15
6406.25 20.00 0.92 3.00 95.69 17.15
6406.25 19.00 0.92 3.00 92.16 17.15
6375.00 20.00 0.92 3.00 91.76 17.15
6406.25 19.00 0.92 3.00 91.37 17.15
6468.75 18.00 0.92 2.00 91.37 16.90
6500.00 19.00 0.92 2.00 91.37 16.90
6531.25 18.00 0.92 2.00 91.37 16.90
6593.75 18.00 0.92 2.00 91.37 16.64
6593.75 18.00 0.92 2.00 91.76 16.38
6593.75 18.00 0.90 1.00 91.76 16.90
6718.75 18.00 0.92 1.00 91.76 16.64
6687.50 18.00 0.92 1.00 91.76 16.38
6750.00 18.00 0.92 1.00 92.16 16.38
6781.25 17.00 0.92 2.00 92.16 16.13
6843.75 18.00 0.92 2.00 56.47 2.56
looks pretty good, the second gear pull doesn't show much because you were never wot. though our ecu considers 90%+ wot and enters open-loop. in both gears your getting a small amount of knock 4000-4500 which is normal because thats when max cylinder pressure occurs. you have a nice steady increase in timing, 02's look good. I'd say turn it up to 18 and see what happens.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
