Fidanza Flywheel NEED HELP PLEASE!!!
2gGSXEclipse
397
4
Apr 7, 2008
847, Illinois
Alright the other day I finally got my car back together after rebuilding my transmission, doing a ACT 2100 clutch, and aluminum Fidanza flywheel. I went to go start it and alls i heard was the starter spinning and not engaging with the flywheel, its the right flywheel made for a 7-bolt AWD DSM. Just wondering if anyone knew what it is or has had it happened to you
appreciate it thanks:dsm:
Double check your starter bolts first. If those are good then it sounds like you may have gotten the wrong flywheel. Maybe someone at fidanza messed up?
