Fidanza clutch wont disengage
Luckybob2485
140
Jun 20, 2006
Longmont, Colorado
I had a fidanza 3.2 clutch installed professionally about a month ago. Today, out of nowhere, the clutch just stops disengaging. The car will not go into gear at all. I try to start it in first gear, and it immediately starts jumping and ready to go. Hopefully its something minor.
Have you checked for air in the lines or a bad master/slave cylinder?
Well, it's a pretty stiff clutch. Have you check your clutch pedal assembly? If it was running fine before than something must of broken. Maybe your fork also.:hmm:
I just had the master slave cylinder replaced about 6 months ago. One thing i am not familiar with at all is the transmission area. How would i go about checking for air in the lines? Or narrowing down the possiblities?
