Fiav bypass, ridiculously low idle
300hpbound
91
Mar 20, 2008
Westminster, Colorado
So I did the fiav bypass according to the write up on vfaq. I sealed everything up on the freeze plug and sealed a new tb gasket when I reinstalled the throttle body. I am now dealing with an excessively low idle. I got the vfaq to adjust the biss and it doesn't seem to matter which way I turn the screw it drops even lower either way. At night, I can watch my lights become brighter as I step on the gas because my idle is so low at a stop in drive (it's an auto trans). I basically can't turn my idle up and it's way too low the way it sits now. Any suggestions?
You adjust the BISS with the IAC plug pulled out and to rise the idle you need to turn counter clock wise. Maybe you BISS screw is messed up - I remember getting a new screw from a TB rebuild kit and it was plastic. I few months later it started giving me problems
If your FIAV took a dump and you dont want to spend the money fixing it and it keeps the TB cooler since there's no coolant running through it anymore
What is the point of bypassing it?
The fiav is for cold starts and stuff. When it's cold it allows more air around the throttle plate. Unfortunately it's a spring/wax combo that is supposed to close when it's warm and it adjusts to a warm, low idle, it eventually wears out. It's also a huge source for idle surge, so by bypassing it, even tho it may b the first start up of the day it'll go straight into a warm idle rpm and warm up anyway. I have no more idle surge by doing this. Please someone else chime in if I didn't explain that correctly or have something else to add.
The iac and the isc are the same thing correct? Like I said it doesn't seem to matter which way I screw the biss it goes lower in idle. I know the tps is within spec; and I know they can go bad, but the isc is only three years old, bought brand new from Mitsubishi when it was replaced
