Few questons for you guys!!!
4g63t
1,568
13
Aug 14, 2005
North Iowa, Iowa
I have a few questions for you guys,
:dsm: 1, I baught a used 20g it is a true mitsu 20g how much can it flow and what are the AR'S? and trim?
:dsm: 2, Would I be fine with a 2g piston on 1g rod set up? I herd this can hold upwords of 500hp?
:dsm: 3, What size of injectors will I need to up grade to?
:dsm: 4, Any one know of a good company that can put a new compreser wheel on my 20g. It sucked a filter through and has a chunk of a fin missing.
Assuming it is a TD06H-20G... http://www.stealth316.com/2-3s-compflowmaps.htm
2G piston/1G rod depends on what your power goals are. 500hp at the wheel or crank?
If you want to max out that turbo, 255 pump + AFPR + 720ccs.
Try www.forcedperformance.net
