few questions after the new motor has been fired up
haddixjl
77
Jul 27, 2006
orangevale, California
Sorry for any terrible questions. Searching on my phone doesn't work to well. But here goes
Got my motor put back together it's a stock stroke 2.0 with Manley pistons and no balance shaft.
Problem 1 I have been having is a surge only while its cold. I have read it could be the driver in the ecm or the iac? It goes away once its warm and also if I remove Tue wire from the switch on the throttle body that sees when the throttle is opened. I would like to make it correct any ideas?
Problem 2 I have driven it around for about 100 miles and it seems to idle a little rough almost lopey like a can? Is this due to no balance shaft never had a car without it. It has new plugs tried 2 sets of wires can't find a boost leak or vac sprayed brake cleaner around all the typical spots.
Problem 3 twice today I was running around town and if I stopped for 30 mins or so it would fire up but not idle just die. It would stay running if I feathered the gas pedal but wasn't picking up very quickly. It has a new walboro 190 in it. It had a 255 which I removed in case it was overrunning the fpr. I tested it out when I stopped and tried to fire it up and it came right back on.
Sorry its so long but I am on a time crunch with DMV and need to get this thing smogged
    • george bromwell
    • pma1123
    • Sdcryan1
