JuGs
- 674
- 0
- Jul 20, 2008
Marshall,
Wisconsin
Well Im having 2 issues I can figure out. I cant get my oil pressure gauge to work. I tapped it into the sending unit wire clip and it doesnt read pressure, it jumps up very slightly and when i hit throttle it goes to 0 psi and done nothing more. Whats the cause of this?
My other issue is with my clutch or shifter. When I start the car up for the first time in the morning, its almost impossible to get my car into reverse. Ill litteraly stand on the clutch as hard as I can and use both hands and pull as hard as possible. It just sits and grinds. After a few mins I can finaly get it into reverse. After I drive for a few it will still grind going into revers but only until it pops into gear. It also is hard to get into first every so often, and when down shifting into second it will grind (not ever time though) and i have to double clutch it to down shift. I checked the cables and all see fine to me. I didnt try readjusting then just yet. I also adjusted the master cylinder rod a few times and it helped for a little bit but now its getting worse again. Any tips for this would be great.
but if it ends up fixing your problem then it will be worth it in the end. How bad was it worn once you got it out and took a good look at it? Even if it doesn't completely fix your problem its a good thing to get out of the way before it did cause issues in the future cause eventually it would have.
