dj-t
- 197
- 1
- Nov 30, 2010
Sacramento,
California
97 talon tsi all stock with just OTS koni yellow and Ground Control.
One morning backing down on the driveway in reverse gear and clutch press in. As I hit the sidewalk and the car levels out a little the car suddenly stops like someone had hit the brakes. I thought the parking brake was just not all the way down so I double check and it was. I let go of the clutch gas it a little to get me out on the street. Right when I press the clutch in to go into 1st the car stop rolling and felt like the brakes was press again. So, I moved it in 1st and reverse and the same thing.
Jacked the car up, checked front and rear brakes seems fine all well spun pretty easy by hand. Checked bushings and whatever that's under there that I think might cause this but visually all looks fine. I backed it out and all was fine running and feels as it never had happen. 10mins of driving later it happens again. Now as the speed increases vibration and noise from the rear increases.
I have gotten the tires check if it was off balance. I checked the fluids in diff, transfer case, and trans (redline oils). All four axles visually looks good no torn boots or grease around the area. All four wheels spins easily by hand.
What do you think it could be causing this and how do I go about checking for it?
