Feel like a retard for not knowing this
RedemptioN
Oct 12, 2010
Garden City, Georgia
Ok guys i just installed a act 2100 clutch in my 99 eclipse g/s. Got it all done works like a charm. now i have this transmission fluid and i can not find where the filler bolt is ( where you put the fluid) LOL anyway if you could please help me locate it i would be very much in debt to you. thanks in advance. this is my first import btw
I filled mine through my speed sensor hole with a long skinny funnel. It is almost straight down under your intake elbow right before your throttle body.
Yes there is a black rubber plug above drivers side axle. I think it is in a terrible location and a pain to fill the transmission unless you got really small hands.
++++ on this^ I put a motor in a 95 talon N/A and when i got all done I plugged in the speed sensor and must have had coolant in it and it wouldn't go down all the way and when I took it for a test drive the speedo stopped working. And when I ended up pulling the sensor out to get the coolant out the gear fell off in the trans and i had to pull the trans to get it out and that's how I refilled it. Just be really careful when pulling the sensor out.
